Use the following procedure to change the Connectivity Association (CA) to which a port is associated.
Ensure that the new CA is created at the global level. For information about configuring a CA, see Configure a Connectivity Association.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Disable MACsec on the port:
    no macsec enable
  3. Change the CA to which the port is associated:
    macsec connectivity-association WORD<5-32>
  4. Enable MACsec on the port:
    macsec enable
Change the CA to which a port is associated:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabit 1/2
Switch:1(config-if)#no macsec enable
Switch:1(config-if)#macsec connectivity-association caname12
Switch:1(config-if)#macsec enable
The following table defines parameters for the macsec command.
Variable
Value
connectivity-association WORD<5–32>
Specifies the connectivity-association name as an alpha-numeric ASCII string up to 16 characters long. The device uses this value for the connectivity-association key name (CKN).
Tip:
Configure the CKN in multiples of 4 characters to avoid MKA interoperability issues between Fabric Engine switches and EXOS or Switch Engine switches. For example, Macsecma (8 chararcters) or Macsecmka123 (12 characters) are valid, but Macsec (6 characters) is not valid.
The following table defines parameters for the interface gigabitethernet command.
Variable
Value
Specifies the port to associate with the connectivity association (CA).
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
